Which set of control arms and driveshafts?
I'm currently running the Rough Country 4" X-series lift with all 8 adjustable arms and have had no problems. I've been running it since August. They are really beefy and easy to adjust as we'll as easy to rebuild if need be. The other good thing is if you decide go a little higher they can be adjusted up to 6" of lift. I think it's the best bang for the buck.
I just thought of another question, is there really any benefit to replacing the front pinion yoke with new driveshafts? I have noticed that many manufacturers do not replace them. So confused
Ehh
Adams is a reputable brand. Krawls new shaft iirc is on sale.
Depending on lift height you may not need the fronts right away.
Currently I am running a Adams shaft and have my lowers adjusted all the way in.
Generally we do front LCA 's for casters
That's until you install a double carden.
Now pinion is more important.
So wait a minute, if I'm understanding correctly, im going to need rear upper CA's if I replace with adam's drive shafts?!
I just upgraded to a RK 3.5 with lower adj arms and ordered front and rear shafts from Adam's. now I'm broke and find out ill need rear upper CA's?
If you go to the RK site you will see 2 different part numbers for their lowers.
Unlike TF who offers 2 uppers. RK's uppers are longer to work with the longer lowers and move the axle back.
Or ..... If you do want to utilize the lowers in your kit. When ordering have RK shorten the upper arms.
I hope I am not confusing the hell out of you guys :(
- my arms are TF. I did not know and ordered RK rear upper. They are too long to work with my stock lowers.
Instead I got a good deal on a full set of TF arms. Sold the RK's and will sell my current LCA's also.
