Is this set up going to work???
Old Apr 22, 2009 | 06:28 PM
Wildman's Avatar
Default Is this set up going to work???
Ok, I have looked at, I know, hundreds of threads about this lift or that lift. What you should get or could get. It seems, to me anyway, most all kits are not complete kits. I am looking for specifics here from those of you that know more than I do. Please let me know your thoughts on what I'm considering for my 2007 4dr Rubicon auto.
1) 4" Zone lift and shocks $576
2) Skyjacker adj control arms upper & lower, front and back $838
3) Skyjacker dropped pitman arm for 4" lift $85
4) 5 Pro Comp 7089 17"x8 4.5 BS Alloys $670
5) 5 BF Goodgrich 35x12.5 KM2 $1325
Total $3494
Does anyone see anything I've left out?
Any reason not to combine these different suspension components?
I'm looking for as close to stock road ride as possible because it's my daily driver but I want good results on the trail too.
Anyone have a set up similiar to this that they are happy with? If so, what components do you have?
Thanks
Old Apr 22, 2009 | 06:34 PM
mkjeep's Avatar
Think you might do better calling David at Northridge and have him set you up with the suspension. He's very knowledgable and will set u up with a great kit. ImHO, I wish I'd went that route in the first place and went with a total Teraflex kit instead of pieces and parts from different manufacturers.
Old Apr 22, 2009 | 06:41 PM
Wildman's Avatar
Thanks, I'm new, so who is dave and how can I contact him?
Old Apr 22, 2009 | 06:45 PM
paramaniac's Avatar
check my signature line.....
Old Apr 22, 2009 | 06:50 PM
mkjeep's Avatar
Click on the big red letters below, lol
Go to the contact us page and get the number to call him, talk to him and tell him your goals in getting a complete kit.
Old Apr 22, 2009 | 06:53 PM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
also I believe those rims are on back order, most of Pro comps are have been for months, not sure if you've seen it but check outthe sponsers section of forum, Discount tire direct has great deals on tires, can also get rims from them, there is a rebate or two going with them also
Old Apr 22, 2009 | 06:54 PM
Wildman's Avatar
My bad, Rookie mistake.
Old Apr 22, 2009 | 07:05 PM
mkjeep's Avatar
If you wanna go a cheaper route on rims, Summit has black crager soft 8's for $40-$60 each.
Old Apr 22, 2009 | 07:13 PM
David @ Currie Ent.'s Avatar
Former Vendor
The Currie kit is about as complete as they come, just add shocks!!!! We offer a few versions starting at around 1k.
Part #: CE-9807
Our Price:$1,959.95
Description: The RockJock® JK off road suspension system allows for efficient clearance of up to 37" tall tires (with minor trimming) on any model of the 2 door or 4 door Jeep JK Wranglers. Kit allows for up to 11" of rear wheel travel and 9 1/2" of front wheel travel when used with the recommended shocks. Up to 11" of front travel is attainable when used with specific shocks and some minor trimming to the vehicle. This kit is comprised of only the highest end components in the areas of strength, fit, finish, function, and the R&D testing to back them. Included is the set of 8 Johnny Joint adjustable control arms, set of 4 lifted coil springs, front urethane bump stop kit, rear bump stop spacers, rear coil spring retaining kit, front D.O.T. approved stainless braided extended brake line kit, rear D.O.T. approved stainless braided extended brake line kit, front trac bar relocation kit, rear trac bar relocation kit, relocation kit for the tops of the front shocks, relocation kit for the bottoms of the rear shocks, front heim jointed adjustable sway bar links for use with the stock front sway bar, rear heim jointed adjustable sway bar extended links for use with the stock rear sway bar, and a dropped pitman arm. OPTIONS NOTES: Shock options (sold seperately) are Rancho 9000X or 3 different styles of Walker Evans.
BTW, you can also get this from Dave @ Northridge
Old Apr 22, 2009 | 07:40 PM
mkjeep's Avatar
Ain't heard nuthin but good about the Rockjock system as well, nice, very nice.
