Shedding weight
Old Mar 14, 2014 | 07:14 PM
  #41
Matthewd5's Avatar
Originally Posted by Edmond
On my old LJ I was able to shave almost 500 lbs by replacing heavy steel parts with aluminum ones...it made a noticeable difference. On my JKU I decided I would only go with light weight aluminum parts where I can, I did full aluminum skid plates, aluminum rocker guards, aluminum fenders. replaced muffler (saved 8 lbs), for bumpers I went with steel mostly because the weight savings was not that significant and I preferred the look/brand of the steel ones. Teraflex aluminum tire carrier, slightly smaller spare tire (still get me off the trail and home if needed but saves weight and $$). Light weight wheels, Warn RC winch with synthetic line, soft top, half doors....
On this Jeep I went with slightly heavier tires but over all I probably saved 500 lbs in additional weight by choosing aluminum/lighter components.
As far as reducing weight from a stock Jeep... Remove rear seat, remove top, half doors, no spare, carbon fiber/fiberglass body parts, remove stereo, remove AC, remove carpet, remove jack...etc etc... you can get extreme but it depends what your goals are..
Thats great! Where did you find aluminum skid plates? I've gotten my monies worth x3 out of my EVO Pro Tek set...
I have had a bunch of mechanics at the dealership where I go, just for the free oil changes, that the plates have taken some real hits and saved me...
I'm hopingg with the addition of lockers and bigger tires, that I can get through with less skinny pedal!
I'm a big fan of titanium and aluminum, but there weren't any obvious sources when I was getting my skids or bumpers.
matthew
Old Mar 14, 2014 | 07:23 PM
  #42
boon4376's Avatar
Genright has some aluminum stuff - you have to care more about weight than money cause they are expensive as heck... the gas savings from the weight won't make up the cost difference in a decade.
I've also read when thickness is equal, a steel skid plate is about 3x stronger... but most 3/8" aluminum skid plates I'd guess would still be much stronger than the tin can plates that come factory.
I've got steel rock sliders, oil pan -> transmission skid, and diff gliders front and rear for less than the cost of 1 aluminum skid... I'd be worried about the weight of my jeep slamming down on an aluminum slider... but not frame welded steel.
Old Mar 14, 2014 | 07:36 PM
  #43
TOTL Innovations's Avatar
Former Vendor
Originally Posted by Matthewd5
Its usually the cost of getting it professionally painted that kills the projects like that...
matthew
Price is always a factor and my customers see a huge variance in paint prices based on their location and shop of choice.
If budget is extremely tight, the hood is made of fiberglass so it can be run unpainted. I actually have two local customers who are doing exactly that right now. They are running the hoods as is until budget allows to have them painted.
Old Mar 14, 2014 | 07:40 PM
  #44
Edmond's Avatar
I am using ASFIR 4X4 aluminum skids. They are not cheap, I think 3 of them go for about $1500. I believe TNT customs and River Raider also make some aluminum skids.
