shift points
Old Aug 24, 2011 | 03:09 AM
gonup2's Avatar
Default shift points
just wondering if you regear to make up for tire size. will that put your auto shift points back closer to factory setttings? thanks
Old Aug 24, 2011 | 03:29 AM
Jeepcrazed's Avatar
I'm not 100 % but I believe the computer controls this based on your speed/rpm's. In addition to tire size/gear changes I would recommend a flashpaq so you can set up your tire size and gear ratio with the computer.
Old Aug 24, 2011 | 03:39 AM
gerdyj's Avatar
I've regeared my automatic and I'm using a Flashpaq, haven't messed with the shift points but it seems to be fine.
Old Aug 24, 2011 | 03:47 AM
Colegrove03's Avatar
You can buy a programer to help correct this quick. The programers let you chose your gear ratio and tires size and it will automatically put your shift points back to stock. I know superchip does being I own one myself. I regeared to 5.38's when I changed to 37 in tires. on my way home my shift points were all messed up! My friend is a programer for superchips and he told me to change the gear ratio and tire size and it knows what to do with shift points. Problem fixed for me! Night and day it made!
Old Aug 24, 2011 | 04:37 AM
gonup2's Avatar
thanks that what i was thinking was 5.38 and 37's did it hurt your mileage bad . usally get 17 to 18 on highway at speed limit any way. thanks
