Shift Points
I have an 07 unlimited with stock gears and 35's. When I drive on the highway if i set cruise control at 75 it constantly decelerates and then re accelerates. I was told this was because of the shift points as a result of my larger tires. Will buying a superchip like the hypertech one be able to change the shift points?
Are you running with OD on? If so, then you need to turn it off. Superchips will not fix this particular scenario, because the engine with stock gears and 35's doesn't have enough beef to maintain speed in OD. Regardless, I think you should still correct your speedo.
A regear will help but you really should recalibrate it either way. The AEV Procal is the cheapest way to do it. Florida is flat like SC and I don't have that problem on mine. In the mountains is a whole different story.
