shock????????????
Old Jun 9, 2012 | 04:32 PM
overkilljk's Avatar
Default shock????????????
I know it have been talk and talk and talk about. Looking to replace stock Rubicon shock with new one. Want to know if I go with this setup if is ok to run.
Part #55952 front
Extended Collapsed
Length Length
27.40 16.22
Part #55959 rear
Extended Collapsed
Length Length
27.91 16.55 (use bds shock spce for info)
I have a two in space in the front w/oem one. plan on cut up stock fender, Trim the pinch seam and one in body lift to put on 35. make the wires and brake line long are not a big deal to do.
Old Jun 9, 2012 | 10:10 PM
Freewill's Avatar
Try the Bilstein Web site. They will list replacement shocks for a stock Rubi, and show the dimensions. You should be able to tell if the dimensions you have would be close.
