Shock Boots? Gear Upgrade/change
Old Jun 24, 2009 | 09:42 PM
sktdarkstar8's Avatar
Default Shock Boots? Gear Upgrade/change
well im about to install my new teraflex 2.5in coil/shock lift.. im not sure if i should use shock boots.. from what i understand they tend to retain water..? but in turn they tend to lengthin the life span of the shock..? sooo ya, thats why im not to sure b/c the whole retain water but length life does not make much sence to me... any suggestions on what to do.. go with or without them?
second including the new lift comes the new wheels and tires.. im gonna be running true 33's and was wondering if re-gearing is a need? i hear that a lot of people do when they upgrade to bigger tires? if you sugggest that i do, what gears should i go to.. i believe i have a Dana 30.. also when doing a differential change, what is a good oil to use when changing fluid? thanks!
Old Jun 24, 2009 | 09:55 PM
bigbluejk's Avatar
its not 1991. skip the boots. unless you have a time machine and a truck with 18" of lift and 8 shocks on each corner. then get some neon green boots and be happy.
Old Jun 25, 2009 | 03:29 AM
paramaniac's Avatar
what he said....
about your gears, we need a little more info about your rig to figure out what gears you have. year, model etc....
Old Jun 26, 2009 | 07:56 PM
well i have a 07 unlimited x four door.. im not positive on what gears i have....
Old Jun 26, 2009 | 08:09 PM
bigbluejk's Avatar
automatic or stick?
Old Jun 26, 2009 | 09:18 PM
aB²'s Avatar
I have 33's on my JK (3.73 gears) you should be fine without regearing
Old Jun 26, 2009 | 09:44 PM
MPBoxer's Avatar
If it didn't come with a tow package you should have 3.73s for that year. If it did come with a tow package I believe you will have 4.10s.
Old Jun 26, 2009 | 09:52 PM
mkjeep's Avatar
My 07 had 4.10's, no tow package, it was the 24s package.
Old Jun 27, 2009 | 10:44 PM
its a 6 spd.. i dont think its the tow package..? how would you know? it has a tow hook on the front and rear but do you mean tow like hitch? im gonna run 33's and just dont want any thing happening..
Old Aug 14, 2009 | 07:52 AM
jgoard15's Avatar
is it ok to run shocks without the boots.....i am thinking of removing mine from my superlift kit
