shock help!!
Old Jul 2, 2009 | 02:48 PM
sktdarkstar8's Avatar
Default shock help!!
i just installed my TF lift.. but im not sure how tigth to tighten the top shock nut.. theres two rubber washers so the more you tighten the more the washers compress.. when do i stop tighting? also when everything was threw i didnt recenter my wheel caz it seems absolutly fine..? is that ok? thanks..
Old Jul 2, 2009 | 04:31 PM
BaltChief's Avatar
Top front shock goes to 17 ft lbs and bottom is 56 ft lbs.....as for steering, seems that it varys from Jeep to Jeep. Some need to be recentered and some don't.
Old Jul 3, 2009 | 08:30 AM
pastorsteve's Avatar
It may not NEED to be recentered but it would drive me nuts having the wheel not re-centered properly. Have it done when you take it in for your alignment.
Old Jul 3, 2009 | 08:37 AM
the wheel looks perfect.. when driving straight, the wheel looks center.. also how would you torque the upper shock nuts using a torque wrench.. theres no room for it with a socket.. do they make a actual wrench to fit in there that has different torque pounds on it..?
Old Jul 3, 2009 | 08:43 AM
Well brother - if it looks perfect - it's centered.
