shock install help
Old Jun 12, 2011 | 05:25 PM
mkjeep's Avatar
(Arnold voice) Don't be a girlyman, git under der and pushup hard on de bottom!
Old Jun 12, 2011 | 05:27 PM
mkjeep's Avatar
Btw,once you get them in the lower mount, use a large screwdriver or small prybar to get the hole to line up.
Old Jun 12, 2011 | 05:34 PM
blue project's Avatar
Old Jun 12, 2011 | 06:53 PM
BKGM Jeepers's Avatar
This is the easiest approach. Remmber that even pressure and some patience will get the shocks to push up. Once at or near the bolt hole use a screwdriver to push through and hold the shock in place. Then just push the bolt through and force the screwdriver out. Remember to shove the screwdriver in from the side you want the NUT to be on!
I had some PITA shocks to do like this but patience and manliness will get it done!
Old Jun 13, 2011 | 12:08 AM
Gilligan_'s Avatar
i did this once to install new gas shocks on my hardtop...
It seemed like an impossible task until i remembered some grade school science (hot gas = high pressure/cold gas = lower pressure).
I put the gas pistons in the freezer and it lowered the pressure enough to install them, although it still took a little force. It may help just a little bit...
Old Jun 13, 2011 | 05:01 AM
daggo66's Avatar
If you haven't been to the gym lately, the easiest method will be to support your frame on jackstands, disconnect you swaybar, and lower the axle with a jack.
Old Jun 13, 2011 | 05:42 AM
mkjeep's Avatar
Your kiddin right? You couldn't compress those little shocks for the hardtop? Really?
Old Jun 13, 2011 | 04:45 PM
Default so i'm instaling some new shocks
I finally have some new bilsteins and a day off off!!! I'm not exactly a mechanic but i can install basic things like a cold air and such. Should I atempt installing my new shocks? I have any hand tool except jack stands that I might need. I'm thinking I could figure this out. What do those of you that have done this think?
Old Jun 13, 2011 | 05:18 PM
mkjeep's Avatar
Don't think about it, just do it. Not the same shock, a shock is a shock ,but this write-up should help you.
http://project-jk.com/jeep-jk-write-...servoir-shocks
