Shock replacement
Old Aug 20, 2011 | 12:36 PM
pcmasten's Avatar
Veteran: Marine Corp
Default Shock replacement
The passenger side rear shock (sahara stock) is leaking so I ordered a pair of Bilsteins for the rear. Should I be replacing the front shocks also? Will having different type shocks cause ride or handling problems?
Old Aug 20, 2011 | 04:18 PM
RedOffRoad's Avatar
yea replacing just the backs sounds like it will be kind of...rough
Old Aug 20, 2011 | 08:47 PM
pcmasten's Avatar
Well, I needed to replace the shocks anyway since I used shock extenders with the lift. Nothing like a good reason to spend money
Old Aug 20, 2011 | 10:24 PM
Red Dog's Avatar
It is probably better to have the front and back shocks not match than to have one out of the four leaking and totally fail. Getting all four is the way to go.
