Shocks with RK 3.5" kit
Old May 19, 2013 | 09:01 AM
suicideking's Avatar
Originally Posted by EzK
Makes sense. Unfortunately, I don't really get to experience wheeling like that in the mid Atlantic.
Another advantage is the higher end shocks are rebuildable. Break a 5100, you just throw it out and buy another one.
Just think of it as more of a luxury than anything else. You don't need them, but it will improve your ride.
Old May 19, 2013 | 10:08 AM
Biggy's Avatar
Originally Posted by ilikeguns
anyone running the OME shocks with the RK 3.5?
I have the ome long travels and it rides great. My buddy had the same lift with 5100's and mine definitely had a softer ride.
Old May 19, 2013 | 10:53 AM
zero_traction69's Avatar
I am going to be running a rrd racing shock 2.0 with resivar from rock Krawler. Paired with a 3.5 rk dual sport lift. Let you know I lift it when I get it on. Should be tues.
Old May 19, 2013 | 11:48 AM
AaronJK's Avatar
I just put these shocks on, they are amazing. I bought them without the reservoir. They are stiff when cornering, braking, and crawling over obstacles, but they smooth the ride on the road so well you won't feel most bumps.
Sent using my SuperSmartThinky Phone
Old May 19, 2013 | 01:55 PM
JK Inspired's Avatar
I would, if I did.
Old May 19, 2013 | 02:45 PM
Flyer's Avatar
Anyone try the Bilstein 5160s? I heard while they are valved firmer than the 5100, they feel a bit more compliant. A lot of guys here run the 5100s and the OMEs. Have not talked to guy yet who wants to switch.
Old May 20, 2013 | 05:30 AM
13-JKU-Freedom's Avatar
I have the RK 3.5 lift and the recommended 5100 shocks and the ride is great. My only compliant with the setup is RK recommends a front shock with 29" extention and the bilstein are only 27.5" so I loose out on a little bit of droop.
