Shocks and suspention help?
Old Jun 25, 2014 | 01:03 PM
Rubicon01's Avatar
Default Shocks and suspention help?
Hey there guys I need new shocks or maybe even more then just shocks but either way I need help on the subject as well. To start I live in northern canada and this winter was a harsh one around are area. As a result of the harsh winter and very wet spring the roads around the area are absolutely terrible. I drive probably 90% gravel roads, and when I say gravel I mean sloppy, muddy, pot holes, and washboard that will rattle your teeth out. My set up is a 2012 rubicon jku with a 3.5 x-factor with bilstein 5100s sitting on 37" cooper stt's on stock 17s. I chose the bilsteins because all the great reviews I had heard but my jeep rides like a lumber wagon. I have a 2000 dodge 2500 diesel with a block lift that rides like a dream compared to the jeep and it is far from a nice ride. I was wondering if anybody had any thoughts on what shocks would be better, has anyone experienced the same problems, or is there anything else I can do to improve the ride other then the little things like lowest tire pressure. I know it's a jeep and it's not meant to ride like a Cadillac but It seams like it should ride better then it does.
Old Jun 25, 2014 | 02:25 PM
Johns986's Avatar
Default Try changing tire pressure
Looks like you have great shocks, I installed BFG KM2 load E in size 285-75-17 which is 34" on stock wheels with Rubi red shocks and the tire installer filled them to 40psi. The rider was rough and my JKU was a rattle trap. I started to lower the psi and the ride started to improve and it wasn't untill I got to 30psi that I was happy with the ride.
Before the BFG KM2 I had Goodyear Duratracs load D in 285-70-17 which is 33" on stock wheels with same Rubi red shocks and the tire installer filled them to 40psi, the ride was smooth, quiet and perfect I never changed a thing. Go figure.
I think if you play with the tire pressure you can make some improvements and its free and you can do it yourself.
Old Jun 25, 2014 | 02:34 PM
Rubicon01's Avatar
Thanks I have played a bit, I will keep on trying I am starting to think I got the shocks part number mixed up on order tho
Old Jun 25, 2014 | 02:50 PM
Matthewd5's Avatar
I've found that they seem to use higher psi to help mount/balance them and forget to lower it
Don't forget to try the chalk test , my heavy 2 door JK came in right at 24 psi for the 5,200 pound JK with heavy bumpers, winch, rock rails and replaced the factory axle assemblies.
Matthew
Old Jun 25, 2014 | 03:53 PM
TxJeepers's Avatar
Not a fan of the Bilsteins. Buddy has them on his with RK lift and it rides rough. My OME Nitrochargers sports ride much smoother. I think if you've already played with tire pressure and balancing, you should consider the shocks. I think you can still do the Rancho rebate and get a set of their 9k,s for like 250 after rebate plus a 90 day return if you don't like them.
You can get a set of the OME for 400. Get parts 60067L and 60066L.
Old Jun 25, 2014 | 04:08 PM
Rubicon01's Avatar
Would it be worth going for an adjustable shock? Can you play that much with them or is it a pretty narrow field of adjustment
