Short arm or long arm?
Old Oct 1, 2008 | 02:37 PM
Frog Rubicon's Avatar
Default Short arm or long arm?
I will buy a 4" lift kit in December, and I don't know if it's a good idea to buy the short arm lift kit.
I already know that long arm have more articulation off road, and more flex, and honestly, I don't care.
But I ask you 2 questions:
Is the long arm more solid that the short arm?
Is the 4" long arm lift kit is higher than the 4" short arm lift kit?
Old Oct 1, 2008 | 02:41 PM
wayoflife's Avatar
JK-Forum Founder
unless you are planning to go up to 40" tires, i can assure you that JK short arms are plenty long enough and all that you need for up to 37" tires. a 4" long arm kit will NOT be any taller and it certainly isn't any more solid. trust me on this one
Piginajeep's Avatar
not sure what your asking by more solid?
4" long arm will give you the same lift, they use the same shocks and Coils..
Old Oct 1, 2008 | 02:57 PM
jayrav's Avatar
Besides the obvious offroad benefits, but isn't the the long arm kits supposed to give you a better ride on road?
Old Oct 1, 2008 | 03:02 PM
SouthSideSteve's Avatar
if the JK were a vehicle with shorter arms then yes a LA kit would, but the JK's arms are fairly long as it is. So a LA kit wouldn't benefit as much as in a TJ.
Old Oct 1, 2008 | 03:08 PM
Piginajeep's Avatar
4 door and 2 door will make a difference as well.
Old Oct 1, 2008 | 03:10 PM
tgrt's Avatar
Former Vendor
Originally Posted by HITMONEY
...Also it is pretty much a mute point until you go 6" or more in lift... most would never be able to tell the ride difference in a 4" short arm kit and a 4" long arm kit.
x2 on the 5-6" +
tgrt's Avatar
Former Vendor
How so? The arms are the same length I believe.
Old Oct 1, 2008 | 03:15 PM
Piginajeep's Avatar
the length of the jeep comes into play with the ride.
Old Oct 1, 2008 | 03:18 PM
wayoflife's Avatar
JK-Forum Founder
exactly - long arms on a short wheel base jeep will improve the ride a ton.
