should I regear?
Old Jun 7, 2011 | 04:09 AM
blue project's Avatar
Default should I regear?
I have a 2010 2dr sport with auto trans. It came with those wonderfull steel rims and tiny tires. I am going to be running a 275/70/r18 (33") on the sahara rim. Should I regear? I see a lot of higher speeds 50+.
Old Jun 7, 2011 | 04:33 AM
Jeepstown's Avatar
No should not be necessary to change the gears, stock gears and 33's is okay both on and off road.. I ran stock gears and 33's for one year before chaning to 37's and 5,13. and yes i have an auto tranny as well
Old Jun 7, 2011 | 10:14 AM
nthinuf's Avatar
What gears do you have? And have you found the RPM charts in the faq's yet?
Assuming a 32" actual height for the new 33's, you will be looking at:
OD On
3.21's = 1629 rpm @ 70mph
3.73's = 1892 rpm @ 70mph
4.88's = 2476 rpm @ 70mph
5.13's = 2603 rpm @ 70mph
OD Off
3.21's = 2360 rpm @ 70mph
3.73's = 2742 rpm @ 70mph
Just keep OD Off until you get around to a re-gear and taller tires.
