Should I upgrade to lsd when I regear?
Old Apr 15, 2012 | 11:20 AM
brutalvette's Avatar
Default Should I upgrade to lsd when I regear?
I have a '10 sport with d30 3.7 ratio up front. I want to see if it is worth it to put in a Detroit true track LSD or something other than just the open carrier when I regear. Is an LSD going to help off-road? This is my dd and I don't plan on any serious rock crawling. I have been reading that a locker will lead to broken axle shafts, so I am just looking for some more input. Thanks!
Old Apr 15, 2012 | 11:32 AM
olram30's Avatar
another option is a aussie or spartan type locker, still use your same carrier. never used one so i cant say how well they perform. i was in the same situation but i went a diffrent route
Old Apr 15, 2012 | 11:33 AM
wayoflife's Avatar
JK-Forum Founder
yeah, a true track up front would be nice to have but, assuming you've got nothing in the rear, i might consider installing a locker back there first.
Old Apr 15, 2012 | 11:37 AM
olram30's Avatar
some had a lsd in the back, check your build sheet for a anti spin on the back. think the sports with the tow package had them.
Old Apr 15, 2012 | 11:51 AM
arjeeper's Avatar
Agreed you should check your built sheet first to make sure you don't already have one. Even a LSD can be a significant advantage offload over an open differential. Definitely ensure you address the rear axle first before the front (or both).
A LSD can also help in poor weather conditions on-road whereas most "lockers" are only helpful in 4wd low offload.
Old Apr 15, 2012 | 12:23 PM
Sorry I forgot to mention I have the factory LSD in the rear.
Old Apr 15, 2012 | 12:49 PM
Tx98Formula's Avatar
just out of curiosity, how would i go about looking up my build sheet if i bought mine used? I registered my VIN on the Jeep website, is all of that stuff on there?
