Significant Noise, Clutch?
Old Jan 6, 2018 | 11:06 AM
sheppdc's Avatar
Default Significant Noise, Clutch?
Posted about this earlier but have more info now as to what I'm dealing with.
Bought an 2011 JKU with about 60k miles - just finished the last of my work, putting on Duratrac 315/75r16 tires and wheels on Spidertrax 1.25" spacers. I have no lift and Mopar High Top Flares.
First 30 miles were great, but now getting a significant rotational rotational thunk sound from the rear when I'm in neutrual/clutch is disengaged. The sound is there but less noticeable while coasting, but nonexistent while accelerating. The thunk speeds up and slows down with the speed of the Jeep.
Anyone know what I'm dealing with here and what may have brought it on?
Old Jan 6, 2018 | 04:49 PM
sheppdc's Avatar
to add - for the hell of it I tried throwing it into 4WD, at which point the noise/thunk was constant, neutral, accelerating, etc. Getting extremely concerned
Old Jan 7, 2018 | 04:56 AM
hornetman's Avatar
Veteran: Navy
Do you here the noise on start up or is it only after movement? I had a noise/vibration at speeds 50-60 MPH that I swore was coming from under my gas pedal thought for sure was the front drive shaft, removed the front shaft and drove it still had vibration. I ended up replacing/upgrading my front and rear drive shafts (have had a 2 1/2" lift for 5 years and ran 33 now 35" tires), vibration disappeared after driveshaft replacement suspect it was the rear shaft although I didn't have any obvious play or movement. Although you don't have a lift I would check drive shafts first.
Old Jan 7, 2018 | 06:16 AM
sheppdc's Avatar
No sound on startup, only while moving. And to be clear, it’s a pronounced thunk that speeds up with increased speed of the Jeep. Comparable to driving on a flat tire type of thunk.
Old Jan 17, 2018 | 06:40 PM
lessonstar's Avatar
maybe this article can help you,https://www.yourmechanic.com/article...by-tim-charlet
Old Feb 14, 2018 | 08:38 AM
ATTAHO's Avatar
Mine was the rear diff. Similar sounds.
