Simple answer for a lift question
Old Mar 20, 2015 | 09:36 AM
thecapn226's Avatar
Default Simple answer for a lift question
After several days of looking around and calling teraflex I am unable to get a straight answer. I have a JKU Sport with 17" wheels, BFG AT TAKO2 275/70R17. I am looking at a leveling kit (BB, 2" front, 1" back spacers/pucks). Will this lift require a set of spacers to offset the backspacing of the rear, or front, to keep the sway bar from rubbing?
Old Mar 20, 2015 | 09:38 AM
TeraFlex's Avatar
Sponsoring Manufacturer
No it will not be required unless you get closer to a 305 sized tire.
Old Mar 20, 2015 | 09:50 AM
thecapn226's Avatar
Thanks
Old Mar 20, 2015 | 10:26 AM
tarpon4me's Avatar
JK-Forum Ambassador
I also have 33x11 tires on my stock wheels. I'm not sure how your wheels are, but you may find you need to put a couple washers on each side of your steering stops. You may not, but when I went to a 2" lift and 33's on stock wheels, I had an ever so slight rub at full lock/flex. The washer took care of it.
