Size &Type Of Springs
Old Nov 13, 2013 | 02:52 AM
Gman*2007's Avatar
Default Size &Type Of Springs
I'm looking to upgrade my springs from a 3" leveling kit. Should I go with 3" up front & 2" in the back, that is the size of the spacers. Also, what type of spring rate? I've already upgraded all my other suspension parts, including the shocks, control arms & front/rear trac bars.
Old Nov 13, 2013 | 03:57 AM
jadmt's Avatar
JK-Forum Ambassador
I think you will need to list what jeep and how you use it and what your other parts consist of to get an answer.
Old Nov 13, 2013 | 01:57 PM
Gman*2007's Avatar
2012 JKU (Frankenstein) with Metal Cloak upper & lower/front & rear control arms, front/rear JKS adjustable trac bars, front TeraFlex disco's/rear JKS fixed, Bilstein 5160 reservoir shocks. I started out with a Pro Comp 3" level kit & now all that is left is the spacers on top of the 19 rate front springs & 60 rears and the 3" bump stops up front with 2" in rear. I mainly wheel trails & mud right now. Should I just change out the spacer and install 3" longer springs & 2" long in rear. I have LoD full width bumpers and they are heavy.
