SkyJacker Shocks
Old Jun 12, 2007 | 06:51 PM
BigJerm's Avatar
Default SkyJacker Shocks
I have tried using some of the Project Jk write up as help on this but i am still a little blurry on it.
Back ones are on, easy.
Front ones go on tomorrow (would of today but a good Ga summer rain shower rolled up on me). Only question i have is this:
There are 5 pieces for the top. There are 2 silver curved (cup) washers and 2 thick black rubber washers and 1 nut. One rubber washer has a cut out in the middle of it and the other has a raised part in the middle of it and if u put them together they fit perfectly. I am trying to figure out which goes where.
According to this one http://project-jk.com/index.php/?p=81
i place one washer with the curve up, one rubber insert with the step facing up, put it in and on top one rubber washer with the step down and then another washer... but i dont have 2 stepped rubber pieces, only one
Old Jun 12, 2007 | 11:22 PM
wayoflife's Avatar
JK-Forum Founder
Personally, I would just reuse the factory hardware and rubber bushings as they are wider than what you have now with your new shocks and they will have a tighter fit. Just reassemble them the way you took them off
Old Jun 12, 2007 | 11:29 PM
corey3589's Avatar
Thats what I did, reused the OEM hardware and installed the same way as I took off.
Old Jun 13, 2007 | 07:40 AM
BigJerm's Avatar
works for me! thats what ill do today, doing the front ones look to be a breeze
