Is slight "bump steer" normal?
I have a 3" BDS coil lift and about 1" spacers. I have a very slight bump steer on the highway when I hit a dip. I do have an adjustable track bar in order to center the axle but no track bar brackets.
Yes at 3" of lift like you are describing I would expect some slight bump steer due to the steepness of the angles of the drag link and track bars. At your height (3") there is really nothing of you to do as the loss of up travel you would get with a drag link flip. In the rear you can raise the axle side track bar mount that will level out the track bar and it will help you track better down the road and make the jeep a bit more stable in off camber situations.
