slight clicking while slow steering
Old Sep 26, 2013 | 06:41 PM
rodi's Avatar
Default slight clicking while slow steering
I'm having a slight clicking at stop or slow while turning the wheel left. sometimes when I go back right, there's a deeper (but still slight) clunk. any ideas?
installed a TF 2.5 cool lift recently but definitely tightened everything back down. if I remember correctly, I didn't even loosen the front control arm bolts.
track bar? drag link? squirrel?
Old Sep 27, 2013 | 02:38 AM
kjeeper10's Avatar
Vet Army
Clicking can be a lot of things. U-joints ?
How many miles on the axle joints ?
Old Sep 27, 2013 | 03:39 AM
Shearlow's Avatar
+1 on ujoints, also check your shock bolts and sway bar links... pretty much anything that was replaced or messed with when the lift was put on.
Old Sep 27, 2013 | 05:39 AM
rodi's Avatar
14,000 miles. I checked the end links. I'll try the shock mounts. how can I check the u-joints?
thanks fellas!
Old Sep 27, 2013 | 05:43 AM
mook8651's Avatar
If you replaced your track bar look at that the bolts are smaller then the holes an they loosen up after a few
Old Sep 27, 2013 | 08:21 AM
flick's Avatar
x2 on the track bar. I have a friend that is experiencing the same thing you are, and after inspection his track bar is loose on the driver side.
Old Sep 27, 2013 | 09:50 AM
jk.bushwacker's Avatar
CHK U-Joints, ball joints, drag link (sometimes the bolts will hit after you adj steering for a new lift) - if I were to guess its prob your ball joints
Old Sep 27, 2013 | 01:04 PM
ttechris's Avatar
Can you feel the click through the steering wheel? I had a very slight click after installing a lift/bigger tires on my 2012 when I was first pulling out of the driveway(Didn't happen right after I put on those parts, but a month or so later.) After I installed a steering box brace I no longer had the issue...
Old Nov 29, 2013 | 06:05 AM
rodi's Avatar
as an update, this went away completely once my metalcloak GameChanger lift was installed. could have been the trackbar?
