slight wobble/shimmy between 50 &60 mph
Old Oct 1, 2012 | 03:40 PM
silverbackjk's Avatar
Default slight wobble/shimmy between 50 &60 mph
I have a very slight wobble between 50 & 60 mph. it does not matter if road is smooth or rough. I have checked the whole front end and everything looks great. Nothing loose or worn out.
Old Oct 1, 2012 | 03:49 PM
FoxRacingJMC's Avatar
Tires balanced? Proper PSI? What shape is your steering stabilizer in?
Tires new? Maybe you wore out a little tread and now you notice it more....
Old Oct 1, 2012 | 04:21 PM
Tires were balanced a month ago, set at 30psi, tires have 6k on them, steering stabilizer has about 15k on it looks good no leaks or signs of wear. It does seam like the wobble started after a tire rotation and balance.
Old Oct 1, 2012 | 05:05 PM
RedOffRoad's Avatar
Any time I hear shimmy between speeds its almost 9/10 times going to be PSI or balancing issues. 30 psi might be a bit low for your setup, Nitto recommends up to 65 psi for the trail grapplers @ 35", your only rocking half that.
Trail Grappler
Old Oct 1, 2012 | 05:12 PM
k0260's Avatar
I had this issue awhile back. Ended up being a tire out of balance. Rotated tires and no more wobble.
Old Oct 1, 2012 | 05:13 PM
Tonka_yellow's Avatar
What your wheels look like. I had a buddy that couldn't figure a shimmy out and he had a bent steel wheel
Old Oct 1, 2012 | 05:32 PM
I have aluminum ATX. no bends.
Old Oct 1, 2012 | 05:34 PM
Trail Grappler
I did the chalk test for proper ware when i got the tires and have bee running 30psi with no issues till i got them rotated.
Old Oct 1, 2012 | 09:29 PM
gs2offroad's Avatar
out of balance condition, rotate tires and it will probably fix itself.
Old Oct 3, 2012 | 11:10 AM
Just got the tires balanced and the wobble is sightly there at same speeds.
