smittybilt 8000lbs winch enough for JK
Old Oct 29, 2008 | 12:39 PM
lijeepguy's Avatar
Default smittybilt 8000lbs winch enough for JK
well is it enough to take care of most situations , thanks alot guys and gals
Old Oct 29, 2008 | 01:00 PM
mdlott's Avatar
I have the same winch and it's worked fine the 6-7 times I've used it. So far it's recovered 3 JKs (the same one twice), one big tree and a lawn tractor.
Phishjeep's Avatar
No problems so far. And mine is the first gen perm magnet motor. Great deal on the new ones right now.
I probably wouldn't want it if I was winching vertical, but for my purposes its great.
Old Oct 29, 2008 | 01:09 PM
lijeepguy's Avatar
thanks guys, i forgot to mention , i have an unlimited , trail mud , and rockclimb , maybe 12-15 times a yr i hope , just getting back into wheelin after about 12 yrs away from it , i forgot how much fun it is
Old Oct 29, 2008 | 01:49 PM
racer83l's Avatar
Originally Posted by N2rock
Isn't the Unlimited fun to wheel
Until it gets hung up because the wheelbase is SOOOOOOO LOOOONNNGGGGG
Old Oct 29, 2008 | 02:17 PM
JeepinMass's Avatar
It should work for most situations. Make sure to get a snatch block incase you need to boost up the the pulling power.
Old Oct 29, 2008 | 02:23 PM
lijeepguy's Avatar
1 more ? for you guys , should i replace the cable with synthetic , im getting it from a friend , very reasonble price , its only got 1 pull on it , is the snthetic worth the price or just run the cable ?
Old Oct 29, 2008 | 02:29 PM
yoshillopez's Avatar
I say go for the synthetic. The amount of weight you'll save is worth it....not to mention the safety factor. I just got done installing the superwinch lp8500 and swapped out to synthetic.
Old Oct 29, 2008 | 02:31 PM
JeepinMass's Avatar
If you use synthetic make sure to always check if the line is rubbing on something during a pull.
Old Oct 29, 2008 | 02:32 PM
Geeper4x4's Avatar
It will work fine but as others have said it is slow. If you are getting a deal on it go for it.
