Which Smittybilt Winch
I am strongly considering getting the Smittybilt XRC front bumper. So I am looking for a winch to go with it. I am looking at the Smitty winches also. I like their new X20 winches, but I don't know if it is worth it to get the comp series.
It looks like the only difference is synthetic rope for the comp series. I was thinking the 8000 lb one so the difference in price is 150 between the two. Is it worth that for synthetic and also is 8000 pounds enough for a two door with no other major mods?
On a side note should I even go with a winch/bumper first or should I do tires and wheels? I can really only afford one or the other right now. And the tires would only be 33s because I can't do a lift other than Rubi springs.
Thanks for all the help.
I'm biased as I have an XRC10 Comp. I would say the extra $100- $150 for synthetic is worth it, if for nothing more than it saves you 30-35lbs of weight. I think the XRC8 would be ok for a 2 door.
All about personal preference.. Dropping the weight and no little wire splinters is a pretty good pro... On the other hand, weather/elements are harder on synthetic rope, and I would not want wrather have my steel line rubbing on a rock or tree as well... Like I said, it's really a personal preference in my opinion. I'm running an Xrc10 with steel line and think its def worth the $399 shipped...
Originally Posted by Pushrod
I went bumper / winch route first as I figured that I could always get stuck no matter what size tires and lift I had on the Jeep. It is really what you are going to do the most with your rig though. If you are after looks more than function then recovery may not be your biggest concern. Personally I do a lot of offroad alone and can't rely on someone to pull me out so the winch was a must have for me. I am still on stock Rubicon wheels & tires for a while until I wear the tires out.
Thanks for all the advice
