Smittybilt XRC 8 Problem
Old Apr 5, 2009 | 01:40 PM
mpuch's Avatar
Default Smittybilt XRC 8 Problem
Got my brand new XRC 8 all mounted up and it does not work at all...nothing.
I have checked the wiring scheme countless times and it is definitely hooked up correctly.
I am guessing it is something to do with the plug in remote...any suggestions...
Old Apr 5, 2009 | 02:51 PM
pagoda's Avatar
Explain "not working"
1. Are you trying it with the engine on?
2. Are you able to manually unspool the cable?
3. After you put plugged in the control stick, did you turn it to lock it in?
Old Apr 5, 2009 | 03:14 PM
milehighjk's Avatar
my remote would only work one way i plugged it in backwards nothing happened ,
switched around and worked fine
Old Apr 5, 2009 | 03:27 PM
bOLsAK=3's Avatar
What about checking the fuses?
Old Apr 5, 2009 | 04:34 PM
nangulator's Avatar
X2, never forget the basics
Old Apr 5, 2009 | 05:14 PM
angel's Avatar
I have oner to and I had the same problem antell after I pluged my remote in and turned it to the right ...I t worked then...try it
Old Apr 5, 2009 | 07:05 PM
mpuch's Avatar
got it guys, thanks. i guess I just had not turned the plug all the way but it is working now...
Old Apr 5, 2009 | 08:17 PM
bOLsAK=3's Avatar
Cool
Old Apr 5, 2009 | 10:53 PM
milehighjk's Avatar
