Snorkel and duel battery set-up
Will a Rugged Ridge XHD snorkel and a duel battery set-up fit/work under the hood of a 2010 JKUR?
I already have the Rugged Ridge light bar, so the XHD is what I'm probably gonna go for when it comes time for a snorkel. Thing is, I'll have 7 Hella 500's and a 8500 lb winch running off the stock battery/alternator set-up. So a duel battery set-up is probably in the future also.
Will these two conflict?
Regards,
Trent
Regards,
Trent
Yep, it will work.
Features:
The modular design allows you to choose a Pre-filter Low Mount or Ram High Mount design.
Works with other popular Rugged Ridge® accessories like: Dual Battery Trays, Windshield Light Bars & Windshield Light Mounting Tabs.
Installs with minor modification of the fender. Unlike other kits that require cutting large holes in the firewall, fender or hood!
Features:
The RR snorkel and AEV's snorkel both work with dual batteries.
AEV's roof height snorkel can also have windshield lights (depends upon the specific light mounting brackets you use), whereas RR's snorkel can only be the shorter hood height version, not roof height, to use windshield lights.
