Snorkel questions...
Old Aug 22, 2011 | 07:53 AM
Jeremy072288's Avatar
Default Snorkel questions...
I just installed my snorkel and I have a couple questions....
Is there anyway I can see if the intake is 100% sealed? Can I go in drive through car washes? What all do I have to waterproof in the engine bay to be able to completely submerge my jeep?
Old Aug 22, 2011 | 07:56 AM
Croce's Avatar
For my AEV one. Once the RTV sealant was finished curing, i filled my bathtub with water and stuck the snorkel and airbox in there to see if any water came in
Also im not sure your going to be able to "completely" your jeep. Theres alot of electronics under the center console that if they get wet may cause some issues
Edit: Dont forget to extend your 4 breather hoses
Old Aug 22, 2011 | 08:00 AM
Dang I didn't even think of doing that! I used a lot of silicon to seal any possible way of water finding itself in. Before I test it I gonna silicon one more time
Old Aug 22, 2011 | 08:01 AM
Yea I still need to do that
Old Aug 22, 2011 | 08:06 AM
Croce's Avatar
Did you silicone the holes on the bottom of the airbox too? i did and they still leaked so i used a whole lot of RTV sealant there
Old Aug 22, 2011 | 08:10 AM
I silicones those really heavy. They seemed to be the hardest for some reason
Old Aug 23, 2011 | 06:28 PM
Bump! Still have unanswered questions. Thanks
Old Aug 23, 2011 | 07:02 PM
Fenrir's Avatar
With my airbox opened up, I poured water just on the area where the snorkel meets the airbox. I noticed a few small drips making its way through, into the airbox. I also noticed that my holes on the bottom were leaking a lot.
I kept applying silicone at the snorkel/airbox connecton and used a lot of silicone on the holes at the bottom of the airbox. I siliconed from the inside and haven't had any issues. Dry as can be. I still need to extend my breather tubes.
Old Aug 23, 2011 | 07:37 PM
Fenrir's Avatar
Originally Posted by ludski
im getting my snorkel in this friday. and i plan on extending my breathers as well.
And I don't see your name on the Drummond Island trip! You'll be ready for it with that Snorkel!
Old Aug 23, 2011 | 08:06 PM
JeepFish's Avatar
Best (safest) way to check ur seal is: with the jeep running, take off the top and place ur palm on top of the snorkel. You should feel the suction on ur hand. If u have a perfect seal u should cause the jeep to stall since ur cutting off airflow. If it keeps running u have a weak spot.
