So Here is a 15" rim thread
Old Feb 18, 2008 | 07:50 AM
The_Captain's Avatar
Talking So Here is a 15" rim thread
Well, It is hard to search for rim size, so Who here has mounted a 15 wheel, without trouble, or with trouble, and what you had to do to make it fit....
I would like a 15" rim, because more tire size availability, and they are cheaper, and I don't have much spare moolah.
If anyone is running a cragar soft 8 black wheel, 15x8. what backspacing and you get a cookie... Around 40 bucks for a black steel wheel is what I am talking about...
If you do have 15's, please post what make and model, if they fit, or how you had to make them fit, and any pics, would look cool. Also the reason you went with the 15's.
Thanks in advance
Old Feb 18, 2008 | 08:56 AM
07JKRUBI's Avatar
There is an extensive 15" rim thread in the show and tell area. I f I kew how to post a link to it I would . Good luck!!
Old Feb 18, 2008 | 09:15 AM
fraud's Avatar
https://www.jk-forum.com/forums/jk-show-tell-33/official-show-me-your-jk-15-inch-wheels-thread-7758/
Old Feb 18, 2008 | 10:36 AM
Cool Oh, well then
Ahem, shoud've looked longer. Thanks guys.
Old Feb 19, 2008 | 05:37 AM
07JKXRG's Avatar
Default My Experience
Heads up Friend.
I DID buy these rims last week!!!
Cragar Soft 8's 15X8 4" BS from Summit
Based on the info of this and other websites there shouldn't have been no issues, but........
Was I Surprised!!!!!!!!
Rims were rubbing hard in the front on the Brake calipers. Could not even turn them by hand. I looked at the situation and determined that it was worth the attemp to make it work.
I used a diegrinder with 60 grit roll-lock pad and removed some "high spots" from the calipers at both ends(top and bottom corners) and from what i consider the outboard side approximate 1/16". Once that was completed , 10 min, the rims were clear of rubbing, which when you spin the wheel there is no noise except the actual brake pads on the rotor sound.
The rear was clear!
I am confident that the minor grinding is of no harm to my brake system.
Installed the rims and 35x 12.50x 15 BFG AT and love it.
Hope this helps you or the next fellow jeepers
Old Feb 19, 2008 | 05:54 AM
merfsiu's Avatar
Originally Posted by 07JKXRG
Heads up Friend.
The rear was clear!
You are the 2nd person i have heard of having problems with cragar soft 8s.
Well anyway. I have cragar soft 8s 15X8 4" bs mounted on both of my JKs with no problems at all.
Old Feb 19, 2008 | 09:47 AM
Talking sweet
Thanks guys. Now I can get some good rims. Now all I gotta do is wait for may, and my rebate.... oh well......
