So I decided to rewire my lockers...
I got the switches from Over the River.
otrattw.com
Really nice guy. Note, there are a couple of different switch designs that you can use, not all are wired the same.
Here is the wiring schematic I made. I completely bypassed everything in the jeep. Now they are stand alone switches and the Jeep is basically no longer connected to the diffs.
You will also notice that I only had to run a total for 4 wires through the firewall to get it all done, then 2 to the front and 2 to the rear.
otrattw.com
can you control the front and the rear locker separately in the rubicon edition? Cause the wiring kit I saw online uses one switch for both lockers... No? So how did you separate them into two switches?
Looks AMAZING man. Great job.
Great job, I'd have mine down lower since I have elec windows but like how they light up, etc.
The lockers draw less than 20 amps when they are both tuned on, I am assuming this since they share a 20 amp fuse
Yes, this bypasses the factory system completely. I can control the front and rear seperatly.
The wiring at the locker is very strait forward:
The locker requires a power and a ground to engage. Ground 1 side and send power to the other from the switch. The contact that the factory uses to confirm engagement is just a connection switch, it does not do anything but complete a separate circuit when the locker engages. So, I grounded one side and sent the other side to the ground of the 2nd switch light.
