So i think i blew my engine
Old Apr 17, 2013 | 06:09 AM
JKX08's Avatar
Default So i think i blew my engine
I was going down i80 and was passing as my engine started to knock and I pulled over and shut down but now it won't start .... I can turn the engine by hand but not as easy as it should ... I'm still under warranty barely ... I have it home now but does anyone know a mod friendly dealer in the south suburbs of Chicago?
Old Apr 17, 2013 | 06:15 AM
Ryan0260's Avatar
Is there oil in it?
Old Apr 17, 2013 | 06:25 AM
JKX08's Avatar
Yes but it was a little low ... I toped it off and still nothing
Old Apr 17, 2013 | 06:26 AM
SpicedCrusher's Avatar
What's a little low??
Old Apr 17, 2013 | 06:30 AM
JK-Ford's Avatar
Starter turning the engine? Or turn the key and nothing?
Old Apr 17, 2013 | 06:34 AM
JKX08's Avatar
It will start to crank and then stops and clicks like a dead battery ... Battery voltage is good right around 12.6
Old Apr 17, 2013 | 06:41 AM
JK-Ford's Avatar
Have you tried a jump-start? Voltage can read good on a bad battery.
Old Apr 17, 2013 | 06:51 AM
Tweakecho's Avatar
A bad battery will have similar symptoms, mine left me on the side of the interstate. Voltage showed "good" at 13.8VDC. Untill they put the load test on the bat. Mine then was putting out 4 amps on a 600amp battery. Swap with another car first to see or take it to your local shop for a load test.
Old Apr 17, 2013 | 06:54 AM
JK-Ford's Avatar
Originally Posted by Tweakecho
Swap with another car first .
Or Jump Start?
Old Apr 17, 2013 | 07:04 AM
Tweakecho's Avatar
Or Jump Start?
The reason i said swap is because my "bad" battery did not let the jump work properly. The battery must have been "eating" the jump voltage. It would almost start with jump, but fired right up with a different battery.
But its troubleshooting that sucks i thought something bad was wrong as my DISPLAY was acting all sorts of screwy. Hope its not a blown motor for sure though.
