Soft Break Pedal After Axle Swap ?
So I swapped out my stock axles with Dynatrac 60’s, which also included going to a larger brake set-up (14.25”) - now my brake pedal travels almost to the floor. Don’t misunderstand me, the truck stops - but I waaay prefer the ‘stock’ feel as opposed to the nail biting, heart stopping trip to the floor my foot does now. Anyone else have an issue like this when going to larger brake? Is a larger MC the answer - thoughts ? .... Neville |
Try bleeding the brakes(I imagine you bled them once). To truly bleed the brakes you may have to take it to the dealer unless you have access to a "dealer tool" which is software to activate the abs so that you can assure the air is out of there too.
You definitely have air in your brake system, and definitely need to bleed your brakes.
It's really easy, just make sure you have a friend to help you pump the brakes. Start at the rear passenger side, and move towards the master cylinder. Good luck, and have fun wheeling those 60's. |
Hummmm - ‘never heard of a ABS bleed procedure. The breaks were bled twice and all seemed normal - also, the ABS was disabled at the time (kill switch) so ‘not sure if that makes a difference. i’ll investigare this ABS bleed procedure (that’s certainly the lesser of the two evils) - but I think I may have to start thinking of a larger MC ... |
Somethings it takes a while to get the air out. Yes abs bleed requires a scan tool. I have alwasys been able to got the air out the standard bleeding way but the last time I had the brakes of I could not and would get a random pedal to the floor. I had to do the abs bleed 3 times.
If you pump the pedal a few times does it give a more solid pedal feel? If so, then you most likely have air in the system. If not, you may very well need a M/C with a larger bore or longer piston travel.
Originally Posted by fromme
(Post 4311407)
I ended up spending an hour (and the better part of a bottle of Gibson’s) on the internet to find out the best out of two options I had for a larger MC. So that’s my next Saturday planned out - I will let everyone know the results next week .... |
I will add that I installed dynatrac 60s front and rear in my LJ and experienced a softer pedal feel like you describe. But it still stopped well running 39” Krawler stickies. I didn’t like the pedal feel but it worked so I left it alone. It got better as the pads bedded in too. How do the brakes perform? |
As mentioned, the brakes do work / stop the truck - the pedal just feels like the clutch (almost) ! increasing the volume of brake fluid with a larger MC makes sense - especially now I am 100% sure air in the lines is not the culprit. The truck is now perched on 40”s - likely this is something I should of thought of / addressed when planning out the build ....https://cimg3.ibsrv.net/gimg/www.jk-...e1bc4c3e2.jpeg |
Cant help with the brake issue but just had to say what a beautiful Jeep you have there!
:rock: |
