Soften up the ride?
Old Oct 4, 2010 | 05:20 AM
Din's Avatar
Din
Default Soften up the ride?
I bought a used 4in pro comp lift and believe it came with the ES series shock. I can feel every bump in the road especially with 35 tires. Is there anyway I can soften up the ride? Would changing to a better shock help? If so what are some good recommendations of a softer shock that wouldnt really break the bank. thank you.
Old Oct 4, 2010 | 05:23 AM
bahadden's Avatar
how many psi are you running in your tire?, you may want to lower it..
Old Oct 4, 2010 | 05:32 AM
Din's Avatar
Din
running about 30psi right now. drop it lower?
Old Oct 4, 2010 | 05:34 AM
Jerrod710's Avatar
Were the shocks used as well? Maybe the shocks are shot, just a suggestion.
Sent from my ADR6300 using Tapatalk
Old Oct 4, 2010 | 05:42 AM
Din's Avatar
Din
The shocks were used. Before we put them in we "tested" them by pushing down on them seemed ok. I dont mind buying a better shock if needed.
Old Oct 4, 2010 | 05:46 AM
bahadden's Avatar
you could try, if your tire is running a good contact patch them no, if your shocks are shot it I would think it to be a bouncy ride. is it a hd lift? or for an unlimited and you have a 2dr?
Old Oct 4, 2010 | 05:48 AM
Jerrod710's Avatar
It's hard to tell if the ride being stiffer as normal or not cause sometimes it depends on the lift kit, some lifts ride rough. The one on my K5 blazer is the roughest ride I have ever rode in or drove and had no flex.
Old Oct 4, 2010 | 05:49 AM
Din's Avatar
Din
yeah its not bouncy its just "rough" my wife complains and she drives the jeep daily. By HD do you mean heavy duty? If so Im not sure. All I installed were taller springs front and rear, shocks, stabilizer end links and rear trackball bracket. Guy I bought from said it was a pro comp lift.
Old Oct 4, 2010 | 05:56 AM
dooz's Avatar
If your shocks were shot, it would be really bouncy and you wouldnt be looking for a softer ride
My ride is rough like hell too, i was thinking about replacing the shocks. Looking for soft ride shocks recommandations too ;
Old Oct 4, 2010 | 05:57 AM
bahadden's Avatar
yeah, heavy duty which would have an increased spring rate for heavier bumpers ect. I enjoy the ride out of my rancho rs9000xl and they are adjustable
