Softtop Help
Old Mar 1, 2015 | 11:04 AM
14Sport's Avatar
The weatherstrip came with it. It was peel and stick and believe it or not it was straight when I first installed it. I think the constant latching and unlatching made it gradually move out. The passenger side looks pretty much the same.
Old Mar 1, 2015 | 11:55 AM
Scrappi's Avatar
Hummmm. Well this isnt promising. I had the supertop NX (non twill) before this one and it fit perfectly. Sounds like the header wasnt molded correctly. Mine is so loud that I have to yell to talk to my passenger. And I have a road trip planned so not looking good here
Old Mar 1, 2015 | 12:05 PM
14Sport's Avatar
I haven't checked but maybe the footman loop has some play in it. Try loosening it and pulling it lower. You could always elongate the top of the bolt hole in the loop and drop it lower as well. Just a thought.
Old Mar 1, 2015 | 01:35 PM
Scrappi's Avatar
Good idea. Lemme go look into that.
Old Mar 1, 2015 | 02:58 PM
Scrappi's Avatar
loop not loose at all. not sure how to modify it tho
Old Mar 1, 2015 | 04:44 PM
14Sport's Avatar
You would have to remove it and use a drill or a file to make the bolt holes bigger (just at the top) so you could push it down a little and tighten.
Like this, where the black is the stock hole and the red is how you made it bigger.
Old Mar 1, 2015 | 05:44 PM
Scrappi's Avatar
You would have to remove it and use a drill or a file to make the bolt holes bigger (just at the top) so you could push it down a little and tighten. Like this, where the black is the stock hole and the red is how you made it bigger.
gotcha
