SOLID dif covers and dif fluid?
Old Mar 17, 2009 | 10:09 PM
jvalason's Avatar
Default SOLID dif covers and dif fluid?
For anyone that has Solid covers on a X, how much fluid did you use for the 44 rear and 30 front?
Old Mar 17, 2009 | 11:37 PM
nthinuf's Avatar
http://project-jk.com/jeep-jk-write-...hange-write-up
Step 6 in that write-up...
6. Fill up your Jeep JK Wrangler’s differential with SAE 75W-90 synthetic gear oil. The Front differential only needs 2.7 pints (1.35 quarts) and the rear only needs 4.75 pints (2.375 quarts). If you have factory covers, all you need to do is fill up your differentials until gear oil oozes out of the fill hole. If you have an after market differential cover that has a higher fill hole (like a SOLID or ARB), DO NOT be tempted to fill up your differential with any more gear oil than it needs as it will just end up getting pumped out of the breather tube and make a big stinking mess.
Old Mar 19, 2009 | 06:56 PM
jvalason's Avatar
Thats for 2 dana 44's though. How much do you add for a dana 30 with a SOLID cover?
Old Mar 19, 2009 | 10:54 PM
reddragons's Avatar
Originally Posted by toad
Usually the front takes 2 bottles. The back takes about 2 1/2. Bullfrog devised a great way to check the fluid before it gets all over the place..take a paperclip and bend out a side and use that as a dipstick in the filler hole to check how much fluid you have. If it has oil on it, you're good.
Simple, but a great idea. I'm impressed.
Old Mar 20, 2009 | 01:13 AM
jvalason's Avatar
Thanks!
Old Mar 20, 2009 | 03:34 AM
JackMac4's Avatar
Not according to Eddie's write-up. 2 bottles is way more than is recommended up front.
