Solutions yet to Speedometer with larger tires
I know this has been discussed over and over, but I have never actually seen any solution. Has anyone found a unit that will reset the speedometer yet?
Either Red Rock or Northridge carries a manufacturer that is releasing some, I can't remember who it was. I remember one of those guys stating it on a thread here.
I know they don't have one for the JK yet but...
I had the Superlift TruSpeed on my TJ. constant problems. First One was bad so they replaced it. The second one would need calibrating every 4-6 months for some strange reason? Not sure how it would constantly get off. Was told it was user error.
I hope when the time comes when I need one either there are more options out there or people have nothing but good things to say about the TruSpeed.
I was wondering if changing the gears to accomodate the larger tires does anything to the speedo reading? I am not sure where the speedo picks up the RPM, if its from the tranny, it should change when the gearing is modified. But if its on the tires or axels gearing changes won't make any difference.
Anyone who has changed the gears should know...
If it does change, what gearing change would result in an appropriate speedo reading for a tire size increase from 31" to 35"?
