Something don't seem right
Old Mar 11, 2011 | 04:35 PM
  #21
wazooz2424's Avatar
Never heard the heat thing. Doesn't make sense, either. It's the AC that cuts mileage from the compressor running. Ever notice that vehicles are "slower" web the AC is on? Doesn't happen with the heat.
Old Mar 11, 2011 | 06:13 PM
  #22
bailey1575's Avatar
yep if running defroster then ac running but that much increase
Old Mar 11, 2011 | 06:24 PM
  #23
D_engel's Avatar
i can get close to 21mpg with rubi 32's and 4.10s. Ill be making the switch to 35's soon so well see where that puts me
Old Mar 11, 2011 | 06:58 PM
  #24
Pushrod's Avatar
I consistently get 21 mpg hwy and 17 -18 mpg around town. I would love to get 37's but I am afraid I will end up with 12-15 mpg , and the way gas prices are going up it just wouldn't make me a happy Jeeper.
Old Mar 11, 2011 | 07:05 PM
  #25
RodCyn's Avatar
I just put on 35's and running 4.10 gears on an automatic. I'm averaging 16-18 city/hwy combined and 18-21 highway only. City only driving drops me into the 15-16 range.
Old Mar 11, 2011 | 07:14 PM
  #26
2saharas's Avatar
You can in theory get better mileage with the installation of slightly larger tires. Look at the ever so referred to gear ratio and tire size chart. If you go from a 32" tire, to a taller tire, say 33" your RPMs at speed will be slightly lower. Running lower RPMs uses less fuel. Now, going from a 32" to a 35" on 3.73 gears will make the engine rev several hundred RPM lower, and the engine will not be running in the main power band and performance MAY be adversely affected.
Old Mar 11, 2011 | 07:15 PM
  #27
4x4Jeeper's Avatar
Originally Posted by Jae Suite
Where do you live that gas is under 3$
That was last month! Were at $3.39 now here in Austin....
Old Mar 11, 2011 | 07:57 PM
  #28
jeepguy553's Avatar
The defrost kicking in the A/C clutch makes sense. I think most cars do that...not unique to JKs. That was what was strange to me...the heater causing the A/C clutch to engage.
On the old CJs we used to use the York A/C compressors for OBA setups and they worked great...but when engaged you could tell a difference in the engine RPMs. With the EFI set up on the AMC 360, I was able to tell the GM ECM that the compressor was engaged and it would kick the idle RPMs up a bit to keep them in the normal to above-normal range. End result? More idle RPMs=more power=more gas used. Plain and simple. The same thing happens when an A/C clutch engages on a JK.
Old Mar 12, 2011 | 03:34 AM
  #29
Jae Suite's Avatar
Damn, I'm at $3.89 in CT
Old Mar 12, 2011 | 04:13 AM
  #30
jk37's Avatar
I get about the same mpg with 32s and 3.73 auto. Was thinking about a 2" lift and 33s but with gas in CA costing more, mabye stock size is best.
