Something's got to give. Which will it be?
Old Nov 6, 2013 | 05:46 PM
Sahara Lee's Avatar
Default Something's got to give. Which will it be?
Ok, so you've upgraded to super strong Chromalloy (or is that Kryptonite) axles. So now...
What is the weakest link? What would you rather break other than an axle on the trail? Carrier? Gears? What is your "fuse" to protect you from being totally disabled on the trail and saddled with expensive repair bills? Differential carrier and gear replacement is not as cheap or easy as popping out an axle and sliding a new one in, now is it?
Twist off a front axle and you have a RWD. Twist off a rear axle and you have a FWD. Still can limp home? Of course you might need minor surgery to remove broken parts, but nothing fancy.
Old Nov 6, 2013 | 06:36 PM
karls's Avatar
The u-joint is still a weak link, the caps can walk out or if your yokes are strong enough then you can break the actual nubs off of the cross. Keep some u-joints in the tool box and you can make it off the trail without much effort.
Sent from my DROID4 using Tapatalk
Old Nov 6, 2013 | 07:25 PM
ABENDX's Avatar
The u-joint should always be the goal for a fuse.
It is the easiest thing to repair on the trail and as KARLS stated, easy to keep a couple of spares and extra u-bolts in the tool box.
Old Nov 7, 2013 | 04:41 AM
familytime's Avatar
JK Forum Regional Rep
Our fuse is to not travel alone,pack extra parts,assemblies,and last not drive like an idiot
Old Nov 13, 2013 | 08:27 PM
Matthewd5's Avatar
Great post!
Old Nov 13, 2013 | 10:19 PM
jkkrawler's Avatar
I run steel beadlocks and heavy military 37s. #1 reason why I haven't and am not upgrading to chromoly shafts. I'd rather snap an axle that shatter my diff.
Old Nov 13, 2013 | 10:40 PM
flomingo's Avatar
I'm still learning but an axle swap sounds like a DIY repair vs. taking it in to get the gears replaced (if you have limited mechanic skills like me!).
This post came at the perfect time since I'm considering going up to 37s and was ready to drop over $1100 on RCV axles! Saved me some serious coin I can put toward something else!
Old Nov 14, 2013 | 04:19 AM
karls's Avatar
Keep in mind that with the heavy tires and factory shafts that you may twist/ shear the splines, so certainly be ready for that situation. Factory axle shafts are cheap and plentiful.....until you need once, then they seem to be scarce.
Old Nov 14, 2013 | 05:13 PM
robsjeep9's Avatar
JK-Forum Ambassador
Ok I'm about to purchase 37" MTR's w Kevlar for my 09 X JKU .... Upfront I have the PR 44 with dynatrac ball joints, Reid knuckles, RCV's and 5.13 gears...... After I add my 37's what's the weak point up front? Or can I wheel it pretty hard? THEN for the rear also 5.13 gears(of course) and I was thinking Yukon chromoly axle shafts in the rear when my ARB air locker goes in. Are you guys saying I shouldn't add the chromoly shafts while the air locker is going in? Are my gears the weak spot if I add the chromoly shafts back there??? What do spare U joints cost? Thanks
Old Nov 14, 2013 | 05:36 PM
JE8154's Avatar
there are no U joints in the rear... If you have RCV's in the front you don't have U joints at all, aside from maybe drive shafts.
