spacer lug nut question (stupid?) (yes)
Old Dec 28, 2007 | 08:26 PM
mattparliament's Avatar
Default spacer lug nut question (stupid?) (yes)
hey guys! I bought a set of wheel spacers from a fellow jk-forumer here and I failed to get any lug nuts with them. My question is, does a "standard" length lug nut work with a standard 17" X model rim? is there a special something I should look for when going to pick up some lug nuts? Thanks guys and gals, I realize this is a trivial question but hey, that's what this place is for, right? Thanks in advance.
Matt
Old Dec 28, 2007 | 08:31 PM
IGOFSHN's Avatar
1/2 20 lug will work. Standard on a JK.
Old Dec 29, 2007 | 02:32 AM
Renegade's Avatar
Are you talking about the nuts that hold the spacer on? Or the lug nuts that hold the wheel on? Your Jeep already has LUG NUTS, right???
Old Dec 29, 2007 | 07:56 AM
kntr's Avatar
What is the cone angle on the stock lug nugs? 45 or 60? This will also be beneficial.
Old Dec 30, 2007 | 02:04 PM
sorry, the lugs to hold on the spacers. I'll probably just have to bring one in to the parts store and make sure it fits. The main concern is if the ends of the lugs that hold the spacers on will not stick out of the hole and hit the rim as it is put on
Old Dec 30, 2007 | 02:14 PM
hig4s's Avatar
Matt
OK, who did you get them from,, we need to get the forum moderators to change their forum rating to JK-lugnut
Old Dec 30, 2007 | 05:57 PM
I told him I was officially nutless....
Old Dec 30, 2007 | 06:02 PM
Renegade's Avatar
Why won't the person you got them from send you the nuts? Or, contact Spidertrax to see if you can buy them directly from them. Good luck.
