Spacers...
Old Jun 10, 2010 | 02:13 PM
NYTUGS's Avatar
Default Spacers...
I have a ? for you guys on spacers, I'm going to be running 33's on "Hulk(commander) wheels)
with a teraflex leveling kit. I was told by a guy at a shop that I was going to need 1 1/4 spacers, around 67 bucks per wheel.....any info would be great!!!! Thanks much, and can you recommend a brand?
Old Jun 10, 2010 | 02:15 PM
dlincoln91's Avatar
Spidertraxs are the way to go and its around $200 for a set of 4 last time i checked
Old Jun 10, 2010 | 02:24 PM
JayhawkJeep's Avatar
Veteran: Navy
+1 on the Spidertrax
Old Jun 10, 2010 | 02:30 PM
Coley's Avatar
+2 Spidertrax
Old Jun 10, 2010 | 03:13 PM
robin's Avatar
what they said!! teraflex's are also good, I would go with whatever is easier to get.
Old Jun 10, 2010 | 03:14 PM
JK-Tex's Avatar
There's no reason to look any further than Spidertrax.
Old Jun 10, 2010 | 04:42 PM
NYTUGS's Avatar
This is a simple install right??? When the guys put the new wheels and tires on they can just pop them on before hand right?
Old Jun 10, 2010 | 04:46 PM
CA-JK's Avatar
Yep, just don't forget to take the little retaining rings off your lugs.
Old Jun 10, 2010 | 04:47 PM
Cpt. Flapjack's Avatar
If you are getting new wheels anyway, why not get the correct backspacing so you don't need spacers?
Coley's Avatar
It's as simple as changing a tire.... but some tire shops won't touch spacers and will claim it's a liability issue.
You're basically taking the wheel off, installing the spacer with threadlock, then installing the wheel over top. You need a jack and a torque wrench. Not hard to do yourself.
