Spacers?
Old Jun 1, 2013 | 10:51 PM
Alsadi94's Avatar
Default Spacers?
Okay so I have a 2012 wrangler sport 2dr
With 33in tires, and the wheels rub. So I want to put spacers on them,
What size spacer would be a good setup? I kind of want it to give it the mean aggressive stance while still performing like it should. And I am definitely not wanting to cheap out either so. What are some really good brands that will hold up to my expectations?
Old Jun 1, 2013 | 10:56 PM
PhotoWrangler's Avatar
Spidertrax seems to be the product leader, and the most suggested.
Old Jun 1, 2013 | 11:59 PM
BlackRockBurner's Avatar
Ran 1.5" Spidertrax spacers for over 3 years with no issues. Follow the instructions, remove the lock washers on the rotors, use LocTite.
Old Jun 2, 2013 | 03:51 AM
catahoula's Avatar
x2! Been using 1.5" Spiders on mine for about 20,0000 no problems. Just check and re-torque if needed. The loctite holds steady.
Old Jun 2, 2013 | 03:54 AM
JK Inspired's Avatar
Tereflex 1.25 on Ours for 2 years
Old Jun 2, 2013 | 04:41 AM
knight1000's Avatar
My spidertrax cost me $180. That saved me about $300 assuming I had went with a cheaper $100 wheel with the correct backspacing. I like how my tires look sitting out just a bit more. I even noticed a little better handling around turns with the wider stance.... not that I drive a JK fast around turns. I checked them at about 1000 miles after install and found 2 nuts a little loose. Retightened with new locktite and checked again at my tire rotation 4000 miles later and they were all solid. Very happy with this option.
Old Jun 2, 2013 | 06:17 AM
k0260's Avatar
1.75" spacers on for 3 yrs+, perfect
Old Jun 2, 2013 | 07:41 AM
Delux2769's Avatar
1.5" Rough Country spacers. $118 for all 4 shipped to my door.
Over 40k miles and over a year. Haven't had any issues with lugs coming loose or anything.
Old Jun 5, 2013 | 10:01 AM
Alsadi94's Avatar
Because I have stock rims will the spacers work with that? And will spacers get rid of tire rub or just make more of a problem ?
Old Jun 5, 2013 | 10:40 AM
whitejeepjk's Avatar
It will get rid of rub if you get 1.5 inch spacers, I was rubbing with with 285 70 17 tires on stock wheels, spider's fixed it
