spacers only on fact. 18's (pics)
Old 01-31-2007, 01:25 PM
TexasChopper's Avatar
Default spacers only on fact. 18's (pics)
My spacers showed up a day earlier then the lift kit, so I decided to put them on and see what they looked like with my factory 18' tires. They are the 1.5 spidertrax.
Old 01-31-2007, 01:26 PM
SLICKWILL's Avatar
thanks great pics
Old 01-31-2007, 01:27 PM
Old 01-31-2007, 01:28 PM
Old 01-31-2007, 01:31 PM
after looking at the huge difference in looks I'm considering not putting my lift on and going with some 33's. Does anyone have any pics of 33's on a 2DR with spacers and no lift?
also does anyone have any info on getting a 33X12.50-18 tire? I just did a few searches and it appears no one makes this size tire
Old 01-31-2007, 01:52 PM
arincmax's Avatar
toyo makes 33x12.50r18 mt
Old 01-31-2007, 02:10 PM
Jake_Blues's Avatar
Dick Cepek, Mickey Thompson, and Interco all make tires in that size as well. I really like my Mickey Thompson Baja M/Ts and they come in that size (actually, it's 325/60R18, which is technically 12.8" wide, but who's counting).
Only problem is I wouldn't put these on a 7.5" wide rim... Min recommended wheel width is 9".
-E
Old 01-31-2007, 02:19 PM
thanks, just found them online. I was thinking about changing if I could save a couple hundred bucks, they are basically the same price. I think once you get into an 18 inch tire it does not make that much difference if I went with a 31 or 37
Old 01-31-2007, 02:49 PM
TwinsJeep's Avatar
Have you looked at the BFG T/A KO - 305/65 R 18. According to the tire-size converter I use: 305/65 R 18 = 33.6 X 12 (manufacturer says: 33.7 X 12.2)... you get a little more height and a little less width than the typical 33X12.5.
I'm considering these for my Sahara Unlimited. My tire guy tells me there won't be any problem putting these on the stock 18 X 7.5 wheels. I'll wait for a leveling kit to come out (they'll probably be out before my Jeep is delivered!) and I suspect I'll need spacers, too. I like these because they'll give me a little more sidewall on my 18s than the BFG 285/65 18s.
Old 01-31-2007, 04:40 PM
JKMAN's Avatar
I have the stock 18's with 35x12.5x18's, no problems. There are allot of vendors for this size as well as 33x12.5x18. I went w/ Cooper STT's and love em. Not quite as wide as the Toyo's so a better fit for the stock wheel. Call a tire shop, there is allot available, Cooper, Toyo, Interco, BFG were the four MT's I narrowed down to. Good luck.
Quick Reply: spacers only on fact. 18's (pics)
