Spare tire
Old Jul 9, 2010 | 03:46 AM
GrimsbyAl's Avatar
Default Spare tire
Ok I need a quick answer. I running 35 and 1 just got killed. Can I put on a stock 32? I need to go about 23km to get th trie fixed.
I have a Sahara, no locker, I will not be in 4wd.
Old Jul 9, 2010 | 03:57 AM
azrwilkinson's Avatar
You will need to put it on in the front. It is going to pull to whatever side you put it on just because of the smaller diameter. You should be ok fo that small amount of time.
Old Jul 9, 2010 | 04:05 AM
GrimsbyAl's Avatar
the flat is on the front so we're ok there. Would lettting air out of the 35 on the other side help?
Old Jul 9, 2010 | 05:13 AM
abock33's Avatar
Letting the air out might help. I wouldn't go over 30mph on that setup. While your at the tire shop I'd get a 35 in spare. even if it's a cheap all terrain it would be better than not at all.
Old Jul 9, 2010 | 05:24 AM
w squared's Avatar
Do yourself a favour and upgrade your spare to a 35 once you get to the tire shop. There's a reason that most of us buy our tires five at a time.
Old Jul 9, 2010 | 06:01 AM
AZ Outlaws's Avatar
X2 it's silly to run a smaller spare than what you have under your Jeep.
Old Jul 9, 2010 | 07:07 AM
GrimsbyAl's Avatar
thank you Mr Obvious.
I didn't have the spare with me, I'm borrowing a tire to go get mine
Old Jul 9, 2010 | 08:49 AM
AZ Outlaws's Avatar
Take it easy Sport... it wasn't obvious in you OP you were driving without a spare and where borrowing one to get where you needed to go. I posted an opinion based on what you wrote. You would be surprised how many people run larger tires and use a smaller and cheaper tire as a spare. Now that's not silly... it's plain stupid.
May I ask what happened to the spare you should of had on your Jeep to begin with?? Curious minds want to know.
Happy trails....
Old Jul 9, 2010 | 09:37 AM
GrimsbyAl's Avatar
It's all good, and all fixed.
The spare was at the garage getting a hole fixed. LOL
yes I was a little short but come on I now had 2 tires with holes, I think anyone would be a little short fused.
sorry I didn't give the whole story I just wanted to make sure I wasn't going to blow my shi* up if I used a smaller tire.
Old Jul 9, 2010 | 10:11 AM
Enteric's Avatar
A spare is there to get you to the tire store. As long as you put it on the front and in 2wd it is not "stupid" to have a cheaper/smaller spare. Otherwise they would not put those little pos donuts in the trunks of 90% of the cars they make. I personally like my spare to match the rest due to the Jeep being so high off the ground, and a small tire having the potential of creating a rollover, but you put your blinkers on and go slow. Just like if you were driving a car with a donut on it. It is not "stupid" however. It is "stupid" if you choose to go over 20-30mph and have one on there.
