Spare Tire Bounce?
Old Mar 23, 2009 | 12:58 PM
l3itch's Avatar
Default Spare Tire Bounce?
So I got my 33" Nitto Mud Grapplers and I was under the impression I would have no problems putting one on the stock tire carrier. It fit fine, but now when I go over big bumps it bounces. Is this bad? Is there a possibility that the carrier will break? It seems to be on there just fine and it's hard for me to move it, but I am pretty sure it's bouncing when I hit the bumps.
And sorry if this is a stupid question that's been asked 1,000 times. Sometimes my searching capabilites suck.
Old Mar 23, 2009 | 01:03 PM
JK-KJ's Avatar
You could try something like this....
ww.ok4wd.com/index.php/catalog/product/daystar_tailgate_bump_stops_for_2007_2008_jeep_wra ngler_jk/
Old Mar 23, 2009 | 01:05 PM
wayoflife's Avatar
JK-Forum Founder
is it safe to assume that the sidewalls are not pressing up against the rubber isolators on the tailgate? if not, you really need to get your spare pressing up against them and that will help out a lot. if you are having a problem with them being too short, daystar makes a set of extended isolators that will do the trick for you.
Old Mar 23, 2009 | 01:20 PM
Calypso's Avatar
Yep, a set of Daystar tailgate bumpstops will fix that. About 12 bucks.
Old Mar 23, 2009 | 01:33 PM
Michigan Mike's Avatar
"Yep, a set of Daystar tailgate bumpstops will fix that. About 12 bucks"
Yeah I got mine from Amazon.com for $14. You DEFINETLY don't want that bad boy bouncin'. Very nasty things could happen.
Old Mar 23, 2009 | 01:41 PM
l3itch's Avatar
Yeah.. just went out there and looked.. not touching the rubber isolators on the tail gate. I will be getting the extenders.
Thanks guys!
I love this forum
Old Mar 23, 2009 | 01:43 PM
Calypso's Avatar
Thanks guys!
I love this forum
They come one size fits all so whenever ya get them you will most likely have to trim a little off.
Old Mar 23, 2009 | 05:31 PM
RubiBurst's Avatar
I put them on when I got my 33's... they work great!
Old Mar 23, 2009 | 06:34 PM
mikeyfl's Avatar
upgrade to 35s and theyll just sit on the bumper.
Old Mar 23, 2009 | 07:31 PM
mkjeep's Avatar
Tighten the bolts where they mount to the body also, or check um at least, mine weren't very tight from the factory. Was behind a jk today and his 35 was bouncin all over.
