Spare tire holder stress?
Originally Posted by tritonman
I just bought some new rims and tires and went the 33 route. The tires are 295/70/17 on a 17x8" rim.
I just replaced the spare and I wanted to know if the spare tire holder will be safe enough and strong enough to hold the new rim/tire? The rims and tires seem pretty heavy to only be held up by 3 lugnuts.
MBRP makes a reinforcement kit, It is a pain to install if you have big hands, but it seems to distribute the load better than stock.
http://www.quadratec.com/products/22202_1001.htm
Ive had my 35 with ATX artillary rim with 4.5 backspace on the stock carrier for over a year with the MBRP reinforcing kit and daystar bump stops. Tight as can be and around 40 dollars in parts. Install not bad , just get some extra bolts for snapping spot welds and make sure thread sticks out a little behind bolt so you have something to unsrew just in case
Originally Posted by second2none
Bestop has one that just replaces the stock carrier and they claim it is good for any tire/wheel combo up to 35" and 200lbs...the part # that you can google is Bestop 61961...they also have a youtube video showing it.
My advice; Yes a 35 and down can work with an "add on" carrier to the gate as long as you do mostly on road driving. I would remove the tire when wheeling (I strap mine down inside now when off road). Would convert to a bumper swing out carrier - recommended.
![Thumb](https://www.jk-forum.com/forums/images/smilies/thumb.gif)
One member used two different re enforcement products to run a 35 safely. I need to find that post. I searched with no luck. Maybe he will post up here.
Thanks for the tips and advice everyone...i decided to order the Off Camber Fabrications Spare Tire Reinforcement Kit and the Daystar Tailgate Bump Stops. Thats why i love these forums!
