spare tire size
Old Sep 25, 2012 | 11:15 AM
Scootersjk's Avatar
Default spare tire size
I have 32 in tires now, looking to go to a 33, can i use the 32 as a spare or could that damage gears or axles etc if needed to be used
Old Sep 25, 2012 | 11:18 AM
JK-Ford's Avatar
Spare tire has to be exactly the same size as the rest on 4WD vehicles.
Old Sep 25, 2012 | 11:21 AM
finfreeze's Avatar
It's a good idea for the spare to be the same size.
If you need it to get off the trail you can use a smaller tire but you would want to keep lockers unlocked and use 4wd only when needed otherwise you could hurt your drive train.
Old Sep 25, 2012 | 11:42 AM
JK-Ford's Avatar
If all you care about is getting home, then just slap on any ole size.
Old Sep 25, 2012 | 11:50 AM
afpilot82's Avatar
JK-Forum Ambassador
Don't skimp, get a full-size spare and rotate it in.
Old Sep 25, 2012 | 11:55 AM
finfreeze's Avatar
Pretty much.
I bought 5 tires to avoid being in this situation. I also do a 5 tire rotation to keep them all close in wear. Not that a brand new 35 of the same make would cause massive amounts of strain on the drive train when being thrown on with tires that have 10k miles on them.
Bottom line, you can't go wrong with a full size spare.
