speedo
Old Feb 9, 2013 | 01:31 PM
AF_SGT's Avatar
Default speedo
So I am about to install my TF 2.5 coil lift and want to know if I will need to recalibrate my speedo. I am currently running 285/70/17 and am calibrated for them. I am just lifting not changing tire size.
Thanks
Old Feb 9, 2013 | 01:36 PM
Rule18's Avatar
No, you're fine. You'd want to recal your speedo if you change tire and/or wheel size.
Old Feb 9, 2013 | 01:40 PM
AF_SGT's Avatar
Sweet. That's what I thought, but since I'm a noob, I thought I better ask. Thanks!
Old Feb 9, 2013 | 02:03 PM
Staytru06's Avatar
Well are those the stock tires that came on the jeep? If not then getting an AEC ProCal to recal your speedo would be a good idea.
Old Feb 9, 2013 | 02:05 PM
AF_SGT's Avatar
No they aren't the stock tires, but it was calibrated when they got put on
Old Feb 9, 2013 | 02:07 PM
pwain's Avatar
Have you verified this? Unless at the dealer I would find it doubtful.
But as far as the lift you are fine. May want to check the aim of your headlights though.
Old Feb 9, 2013 | 02:12 PM
Staytru06's Avatar
Agreed and if you plan on getting bigger tires once you do a lift which you probably will, I'd say the ProCal is a great investment.
Old Feb 9, 2013 | 05:53 PM
AF_SGT's Avatar
It was calibrated at the dealer. I do want 35's sometime down the road and will likely get a procal before that, but it will be after I do some other mods.
Thanks for the help. I'm sure ill be asking.for more of your expertise real soon!
