speedometer cal on a 2010
Old Nov 21, 2009 | 05:57 AM
codysanders's Avatar
i talked with aev yesterday and the pro cal will work with the 2010. no problems that i can see after pluging it in. works great and no worries on warrenty like there is with the performance chips. hope that helps and it will only cost you about 130 bucks.
Old Nov 22, 2009 | 07:47 AM
oryx's Avatar
Default ditto
Ditto for me, the AEV works for my 2010 Wrangler Sport even though it says 2007-09 on the box.
Old Nov 22, 2009 | 08:25 AM
Soopurman0's Avatar
just add 5 mph to whatever speed ur going... bam... calibrated... or use a gps unit that tells you real time speed... all better than spending a bunch of money on something that you use once
Old Nov 22, 2009 | 10:32 AM
joneszj's Avatar
Pretty sure the AEV works on 2010 wranglers. I think I read that it does on Quadratecs site.
Old Nov 22, 2009 | 01:05 PM
mburgess00's Avatar
Hey, thanks all for the insight. I think $129 is a decent price to not have to worry about what percentage off the speedometer is... Just my opinion.
Old Nov 22, 2009 | 04:21 PM
it is not only for spedo correction it helps out your shift points on a auto as well. will make a big difference for gear hunting on hills and you can also change your gear ratio if you swaped yours out. and some other cool stuff too. well worth the 130 bucks.
