Spidertrax question...
I just installed some 1.5" spacers and for some reason my right rear tire sticks out farther than the rest?! Everything is flush, torqued, and checked... any ideas? Its hard to tell in the pic, but I'll attach anyway...
Well..... I'm kind of a newbie to all this... But to answer your question, yes. I have the 2.5" RC BB. As far as adjustable track bar... unless it came with the stock JK, then I don't have it.
since you lifted you jeep, the trackbar is at a steeper angle than it was before. since the trackbar attaches to the passenger side of the jeep and the driver side of the axle, it makes the axle shift towards the passenger side. you can get either an adjustable trackbar, or a trackbar relocation bracket (i know teraflex makes one) that will lower the mounting point on the frame. this will recenter you axle.
Your left front will stick out further than the right front, for the same reasons. The trackbar attaches opposite points up there, swinging your front axle out in the other direction.
It doesnt effect the drivability of the Jeep. Some people dont get the adjustable bars for that reason, it's just aesthetic mainly at lower lift heights. I did get adjustable bars when I lifted mine, because i was setting myself up for a larger lift in the future...
...and the axles being offcentered would drive me batchit.
Thanks everyone! So, it's safe to say that for the time being everything is okay, it's just aesthetics? I'm actually looking into getting the 4" Rough Country lift, so should I be looking into getting the trackbar?
This link is about the adj. front the adj. rear is basically the same concept. It should give you a pretty good idea of what it entails.
Full Traction Suspension Jeep JK Wrangler Adjustable Front Track Bar Installation Write-Up
....that would be a pretty short trip....
so what are you saying...
