Spidertrax Wheel Spacers
Old Jan 16, 2012 | 05:15 PM
Athens_JK's Avatar
Default Spidertrax Wheel Spacers
I am almost in the process of beginning my install for my JK and had a thought about possibly needing wheel spacers. I currently run a stock suspension with stock 17's and 33' BFGoody A/T that causes rubbing when I turn all the way to the left. In my build I will be adding a 4.5 AEV lift with 17x8 ATX Crawl wheels and 35' BFGoody KM2s. I question is simply Should I purchase spacers for possible rubbing and if so should I purchase Spidertax 1.5?
Old Jan 16, 2012 | 05:18 PM
nthinuf's Avatar
If you get proper backspacing on the new rims, then no, you will not need spacers. If you don't, then yes, you will.
Old Jan 16, 2012 | 05:40 PM
delsol5's Avatar
The spacers are super easy to install, and I currently have them on my stock suspension. However, I suggest you research the thread about 35" tires on stock wheels and look at page 7. There is a member who's spidertrax 1.5" spacer broke! It was pretty alarming to see his pics. Just a heads up...
