Spline count and lockers
Ten Factory. Not for strength necessarily, since the metal used should be similar, but for warranty and customer support and availability. They will cover any bend/break, even flanges. Other mfg's apparently like to tell people to pound sand, depending on where/how it was damaged. (if you check on G2 also, verify that the warranty is indeed the same as tenfactory, and get it in writing. We keep seeing contradictory reports...)
If you want stronger, there are several options that get mentioned occasionally. But I don't know if any would be available in a JK 30 spline. Probably just custom mades?
Hadn't heard of this before, cool idea. Not much info to be found so far though, other than a listing for a $1400 kit. Happen to have more insight on the conversion itself?
